I have a lian li pc60 case that I am putting a system in. I have an extra 92 mm fan and also a 120 mm fan that aren't installed yet. Otherwise the fans are the stock ones in the case. I've got and enermax 430 whisper psu with the fans in it too.
Now where should I put the extra fan and what fan should I use should it suck or blow etc. I figure someone has figured out the airflow in this case already and I don't want to reinvent the wheel.
Some things I thought about are:
1) stick the 92mm in the top center and make it exhaust
2) make the stock rear fan an intake and then put a 120 blowhole on top.
I just wanted to get some ideas from you guys before I ripped into the case.
Thanks,
Jeff
Thanks,
Jeff
