- Dec 1, 2003
- Cincinnati
Which 120mm fan would be the best choice on a D-tek Pro Core? I will be using it with a rheostat and want a very quiet setup. I would also like to have RPM sensing as well. I'm currently using the aluminum fan that's rated at 79CFM @ 30dBA @ 2000RPM. That's not bad specs at all. Would the Panaflo H1A be a better choice? It's rated at 103CFM @ 41dBA @ 2500RPM. My thinking is that this would give me greater flow when I wanted it and still be able to make it nearly silent with the rheostat for normal use.
