- Aug 1, 2010
- Austin
Which 12GB (3 x 4GB) for OC'd i7 980?
Hello Overclockers,
I'm in the process of building out a new i7 980x system, and I'm stuck on what RAM to buy It's been awhile since I've built one from scratch.
The machine will be used pretty much 24x7 for stock analysis and back testing. AmiBroker, TradeStation, TickZOOM, etc., will basically keep all cores near 100% while an optimization is running, which can take days. It's highly doubtful a game will ever be installed on this box. (But I threw in an okay? vid card, just in case.)
I want to air OC it to ~4GHz.
These are the three RAM choices I found on Newegg. If there won't be any OC difference or it won't slow down back testing, I'd like the cheaper OCZ
Now (stats of both in lower post) :
~$500 G.SKILL Trident+ Turbulence II 12GB (3 x 4GB)
~$450 G.SKILL Ripjaws
Was:
$300 OCZ Reaper Edition 12GB (3 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333
$400 Mushkin Enhanced Silverline 12GB (3 x 4GB) DDR3 SDRAM DDR3 1333
$460 Mushkin Enhanced Blackline 12GB (3 x 4GB) DDR3 SDRAM DDR3 1600
Rest of system :
i7-980x
ASUS Rampage III Extreme LGA 1366 Intel X58 SATA 6Gb/s USB 3.0
CORSAIR Hydro H70
G.SKILL Phoenix Pro Series FM-25S2S-60GBP2 2.5" 60GB SATA II (SSD)
COOLER MASTER Silent Pro RSA00-AMBAJ3-US 1000W
HIS H575FN1GD Radeon HD 5750 1GB 128-bit GDDR5
Western Digital Caviar Green WD20EARS 2TB SATA 3.0Gb/s 3.5"
Here's the Newegg wishlist
http://secure.newegg.com/WishList/PublicWishDetail.aspx?Source=MSWD&WishListNumber=15263346
Any and all thoughts (or sanity checks) on the other components are highly welcome as well.
Thanks,
Michael
Hello Overclockers,
Was:
Rest of system :
i7-980x
CORSAIR Hydro H70
Thanks,
Michael
