Which AMD 64 939 pin processor is best for overclocking?
l7oc
I'm building a new system for DooM 3 :) and I wanted to know which of the 939 pin processors is the best for overclocking. I'm willing to pay extra if its really worth it.
Thanks!!!
PS: If you guys have any recomendations or my current specs please let me know.
here are the specs im looking at
ASUS A8V Deluxe OR Abit AV8
AMD 64 3500+ OR AMD 3800+ (which is the best for overclocking???)
Corsair- PC3200 DDR 1GB TWINX1024-3200C2PRO (w/LED Display)
ATI X800 XT PE
Wester Digital 250GB SATA - WD2500JD
L
l7oc
Thanks for the advice.
I gotta another question, what motherboard to get.
I have been look at the VIA AV8 and trying to decide between ASUS and ABIT. (Ohh yeah, do you know if they have solved the AGP/PCI lock problem?) Which one do you recommend? OR should I go for the nvidia chipset?
THANKS!!!
Yuriman
The OCFORUMS
If your going to spend that much on a cpu, I suggest getting the cheaper one and phase change cooling, such as Prometeia or vapochill.
