Which BIOS savior does the Abit TH7II-RAID use?
Enigma422
The Parabolic Quantum Well
I have a TH7II-RAID on the way and I like to experiment with beta BIOSes, so a BIOS Savior is a must. Which kind of BIOS savior does this motherboard use? I went to www.mwave.com and I say a RD1-8X 4MBit BIOS Savior and an RD1-PL 2MBit BIOS Savior. Both look like the type of BIOS chip that the Abit TH7II-RAID uses. Thanks.
jdmcnudgent
tOLEDO, OHIO, the heart of it all!
enigma, you can get this board for $149. at essential computers via pricewatch.com. they are in new youk too, so you could either go and pick it up or have it shipped depending on how far away they are from you, its $161. shipped, im ordering tomorrow.:D
MrNatural
Florida
Here's another little trick you can use. Contact Abit support and tell them you were sent a mobo from your place of purchase along with a P4 Woody and when you got it, it wouldn't boot. What they will do then is send you a new bios chip with the 38bios already flashed. All you would need then is an extraction tool which you can pick up at Radio Shack for about $10. Then all you need do is when you have a screwed flash (which is rare) then yank the old chip out, put the new chip in just enough to boot and get to a dos prompt then remove the good chip and place the screwed one back. Then simply reflash it with a good bios and your set to go again. I do it all the time. :D
