I think the gemini looks a little cheezy yet it cools extremely well
rpckvv said:i personally would go with the gemini...
if hoot is willing to get rid of his old WB and use the gemini, it's gotta be good (look at his review of the swiftech, gemini, and maze2 [i think])
im getting the gemini soon, barring any new developments in the WB scene...
-peter
DodgeViper said:
You need to hold one in your hands. It's not cheezy at all. Very well made using Lexan and not plexiglass like others. It's small and cools really well. Hoot and I have simular systems and we both have equal C/W's. I am using mine on a T-bird where the temps are high than a XP.
Yea I have taken this route and the fan noise drove me crazy. I would never have an air-cooled system again if it means having all the fans it takes to move the air to record 39c at full load. Plus in order for you to receive those CPU temps your ambient temps must be really low in the computer enviroment.In comparision I get around 39c full load with same speed and vcore at 1.85 with aircooling.
