I have experiance with PrimoICE... its a bit sticky so dont spill it, but for the new setup its the best. Non-Conductive, Non-Corrosive, Non-Toxic, and it aint that bad on the thermal properties.
Swiftech HyrdrX is most assuredly UV reactive, green in fact.
"Long Life Red" is just red with no UV reactive properties
Pentosin is Red UV reactive, but will look light pink in any other light.
If you use HydrX you don't need iodine. After antifreeze and iodine failed me (Don't quite know why) I've been using Hydrx with no problems for over a year.
The swiftech hydroX is not only UV reactive but even reacts to cold cathode light.
In my case i have no UV lighting but the pipes around the blue cathode and blue LED fans glow extremely bright neon green, and the ones away from cathode are just the green colour as you'd expect it to look.
