Which Fan for AX-7?
Voodoo Rufus
Powder Junkie Moderator
Bakersfield, CA
I wouldn't go for the Panaflo since it isn't quite enough airflow, even though they are quiet. I'd say go for the 68cfm and decrease the speed if the noise is too much and temps are still okay.
Yodums
Senior Member
Ottawa, Canada
Black Hawk said:
choices are:
Panaflo Fan 40CFM
Delta 68CFM
Delta 80CFM
You can make your pic on any criteria, price, sound, temps, etc. Thanks
Delta 80mm, 80cfm.
More performance.
Maybe loud, if you don't really like sound.
Price is only a buck off the Delta 68 and they do sound the same.
The panaflo wouldn't do as good as the Delta's.
Yodums
