Hey guys..
I just recently upgraded to a SLK947U and a Panflo 92mm 56cfm fan .. My temps are good at settings in sig im at 39-40 Idle and 48 Load.. which I think is not bad for 1.8vcore .. but was considering going with a fan that pushes more cfm but also one that wont make me deaf
One consideration is YS-Tech fan because of more cfm and not much noise..
But would the extra 11cfm make much of a difference ?
The other one im considering is the Thermaltake Smart Case Fan 2 ..because of more cfm and at 48db it shouldnt be too loud...right ?
Also should I stick with a 92mm instead or go with the SF2 because of more air flow..
I just wana shave a few degrees off because at 1.85vcore I can run at 2.4mhz stable but the temps get in the lower to mid 50's...
Thanks for any input
Thunda
Thunda
