Which fan is on the Asus 4850 please?
c627627
c(n*199780) Senior Member
Need to replace it but instead of paying to ship the whole card back to Asus [they will not replace fan only, gotta ship the entire card back], maybe it's cheaper to just buy a replacement fan?
Link to card: http://usa.asus.com/product.aspx?P_ID=mi30sCqU6lGnEOdk&templete=2
_____________________
Intel i7 920 [211] BCLK x 19 = 4.0 GHz @ [1.4500] CPU Voltage & [1.35000] QPI/DRAM Uncore Voltage, Batch 3836A394
3 x 1GB G.SKIL DDR3 1333 (PC3 10666) [DDR3-1691MHz] 10-10-10-24 @ 1.64 DRAM Bus Voltage
ASUS P6T Deluxe v.1 [LGA 1366 Intel X58] BIOS 1606
Thermalright Ultra-120 eXtreme 1366 RT with 120mm Scythe S-Flex F fan
ASUS EAH4850 TOP Radeon HD 4850 512MB @ 680 MHz GPU & 2100 MHz Memory
Antec nine hundred case, two front 120mm fans, one back 120mm Fan, one top 200mm fan
Corsair CMPSU-750TX 750W
c627627
c627627
Well, the thing is, 4850 runs so damn hot that replacing the heatsink is pointless, it seems excessive to spend money on heatsink for it to only run stock plus only a little bit more. On the other hand, it may be cheapor + no downtime to buy just a fan instead of paying to ship the entire card back.
I can't figure out which fan or who sells them though? It's kind of circular as you can see on the pic.
Sydney
Reykjavík, Iceland
That fan looks pretty much integrated with the heatsink, I suspect you might have to buy an identical heatsink to get a new fan anyhow.
If it runs so damn hot, then getting a HR-03 is a great idea. Will give you more overclocking headroom as well.
c627627
c627627
Oh well if it's integrated then there's that then. I was not aware there's overclocking headroom on the 4850 to speak of, to make a significant difference?
Sydney
Reykjavík, Iceland
Well, I've never worked with an ATi card, but almost all the nvidia cards I've had could squeeze out another 100MHz on the core on stock voltage.
GT3mich
Birmingham,Michigan
Last Christmas my brother bought a Asus EAH 4870 from Newegg. It appeared to be a good card at the time. After the order was placed I started reading some of the reviews. The fans were failing on nearly all of them. I went to the US Asus site and the card was being complained about in their forums too. Bad fans. I called my brother and told him to expect the fan to fail. It did in early June. He finally brought the card down to me and I put one of these on the card.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118037
Works fine now.
Sydney
Reykjavík, Iceland
Works fine now.
I've got that cooler on my 8800GT, does the job well, although a HR-03 is a much more powerful cooler (albeit more expensive)
c627627
c627627
Wow, thanks for info. It seems that fan failure is a major video card problem historically.
