Which is better, the Thermalright SK6, or the Swiftech MCXC370?
I recently took off my Coolermaster HSF and cleaned up the thermal compound and applied arctic silver2 and am still at the same old temps I was at with the stock gunk on the HSF, case is 26c and cpu is at 34c at idle temps, and using CPU burn with error checking disabled for max heat generation, after 15 minutes I topped off at 43c for the cpu temp and case temp stayed the same, I have a P3 800Mhz and am not overclocking at the moment, two 80mm intake fans at bottom front of case, one 80mm exhaust at top rear of case right below the PS, and of course the PS exhaust fan, I want my temps to be the lowest I can have them before I attempt overclocking. Oh yeah, my room temp where the comp is located is at roughly 18c right now
