which is the best FAN?
Gabertooth
Bismarck, ND (USA)
OC community,
This is kind of a newbie type question, but I can't but any good case fans in my area and I was wondering which you guys would recommend for 80mm and 120mm and which site to but on online?
-Gabertooth
I agree with NasSoccer about the panaflos but he is smoking crack if he think they are cheap at plycon. I buy mine from excess solutions! got 8 92mm panaflos for 35 dollars shipped.
delta's can go up that high but they are extremely loud. so you will have to take them down to 7v to be bearable. go with the panaflos and go to the site el said i think that is where i will go. much better deal there. i guess i should shop around more.
deltas are awesome. you can feel the floor hum.
sanyo denki fans are good too. i had one on my alpha pal 6035 before the delta.
i just ordered two sunon 80 mm 4 pin 2500 rpm case fans. i went with these because they seemed to have a low decible rating. the delta makes enough noise. i dont need anymore.
i've bought some fans from crazypc.com. they have decent prices and a good selection.
i've also ordered from heatsinkfactory.com
