I have a Creative 3DBlaster Riva TNT2 VANTA PCI (a long name, I know it
). I want to take the heatsink off and add a Koolance waterblock to it . I read that you could take it off by either heating it with a hairdryer or by putting it in a freezer. Which is the safest and best way to take the heatsink off?
PS
I have its memory running at MAX 166. I got 170 in the past.
1) Will adding a cheap heatsink (DIY) to the ram chips make it go higher?
2) Does it matter if the GPU is set at a higher speed than its RAM ?
Thanks
PS
Thanks
