- Jan 10, 2012
that's good, if you're in the lower 1.4's on the vcore that should give you some more head room.
run prime for two hours now, if the vcore is low cores will stop working and you just raise the vcore a notch and try again.
if you will look at your folding client you will see it shows a ppd number on the right upper, this is tracked so you can keep up with your production.
