- Jun 19, 2014
Hi all,
I've recently been looking for a new motherboard and CPU. I'm using a GA-990FXA-UD7 Rev 1.1 with an FX-8150 at the moment, and I've pretty much got the basics of overclocking down I think. So obviously, time for an upgrade!
Side-note, I will also be upgrading my cooling system so don't worry about that.
My budget is quite a bit higher than when I bought my current setup, so I think it would be a good idea to switch to Intel. I'm pretty much set on the i7 4790K for my CPU, but I'm a little stuck when it comes to the mobo. I read some reviews but it'd be good to get some input from fellow end-users too.
Right now I'm looking at either the Gigabyte GA-Z97X-Gaming GT: http://www.gigabyte.com/products/product-page.aspx?pid=4969#ov
Or the ASRock Z97 Extreme9: http://www.asrock.com/mb/Intel/Z97 Extreme9/
Mainly because of the Z97 Express chipset, a good audio chip, socket compatibility with the upcoming Broadwell CPUs, and the possibility of SLI/Crossfire with both cards running x16 (I'm currently running 2x GTX 660 which will change in the future as I upgrade further, hopefully to a GTX 780 Ti or an 800-series, but I like the option). Also, I want a board with UEFI instead of the Award BIOS I have now. I want fancy settings dammit!
They both cost about the same, either €217 for the Gigabyte or €237 for the ASRock, both are fine price-wise.
The Gigabyte seems to win out on fan control, which is nice to have ofcourse but not critical.
The Gigabyte is also red and black, which fits with the rest of my system and I just like it in general.
I read the Extreme6 review, which promises good things, so that's a point for the ASRock, assuming the Extreme9 is as good or better.
My case supports E-ATX and XL-ATX so size should not be a problem.
However, my main concern is this:
My current board, a Gigabyte board, turned out to be absolute crap for overclocking and seems to be just low quality overall. SSD performance is really bad too. This series is quite luxurious when it comes to features but apparently very inconsistent quality-wise, and I got the short end of the stick. Hence, I'm kind of worried about buying another Gigabyte board. It'd be much appreciated if someone could tell me if this particular board has the same/similar issues. Reviews indicate no, but reviews are generally not that good at finding quality inconsistensies across multiple boards, so...
Also, Gigabyte has a couple of €300-400 boards (http://www.gigabyte.com/products/product-page.aspx?pid=4963#ov for example) but I can't figure out why those are so much more expensive, and if they're worth the extra money. Any advice on that point would also be much appreciated!
So my question is, which board should I go for, with possible overclocking in mind?
I'm open to other suggestions as well, in case there are better boards in somewhat the same pricerange (a little more pricey is okay, if it's worth the extra cash).
Thanks!
Thanks!
