Which Motherboard do I have?
Glyde
N.Y.
I'm a real newb when it comes to hardware. My question is, how do I cheack what motherboard I have? I'm looking at buying an nVidia Geforce fx 5200 but I need to know if I have an AGP port in the computer I'm buying it for. Where is the motherboard info stored in my comp? O, I'm on XP by the way. Thanks.
Gnufsh
Senior Member
Shasta Lake, California
Just pop the case open and look for an AGP slot.
Check out the "How AGP works," for some info, and to familiarize yourself with what the cards and slots look like:
http://computer.howstuffworks.com/agp.htm
And I attached a picture I've shamelessly copied from ocworkbench.com in which I've circled the AGP slot in red. The retention clip on the end may look different on your board.
G
Glyde
N.Y.
It says I have an: Intel Corporation 82845G/GL/GV Brookdale Host-Hub . I'm popping open my case right now. I would of done that earlier but I didn't know what one looked like.
G
Glyde
N.Y.
O, no. Looks like there isn't one in that comp. So if I get a PCI version of a card would be a hugely significant drop in quality while playing games versus having the same card but with an AGP interface?
deadkenny
Toronto
I would recommend against the FX5200 in any case. With a PCI card you'll end up paying more for worse performance, and have far less choice. If you really need / want a decent video upgrade, I would suggest that you consider upgrading the m/b to one with an AGP slot. A GF4 Ti 4200 or a comparable ATI card would be a more cost effective upgrade than a FX5200.
Xstatic
Rochester, Michigan
a fx5600 is slightly more in price but will yeild better performance. But you will still need agp. Get a cheep mobo for like $60 and put it in there. You will be happy you did.
huneycutt
SC
A friend has a whiz bang 128MB card and I have a 64MB PNY and running typical home user apps like I do we see no difference between his picture and mine. He starts honking on those 3D games and you better believe there's a difference, but since I don't game I'll stick with the old PNY.
