How about doing a little research yourself and tell us what boards you feel fit your needs. We would then have a better idea as to which way to steer you. IMHO.
Basically, do your homework. Read all the reviews and info on the mobo's you think are good, then decide what you are really out to achieve. After a little thought and consideration, narrow it down, then ask for an opinion.
You will be better off that way, who knows? Maybe the mobo you really like is the one people will suggest!!
