- Oct 21, 2003
- Bloomington IL
LINK
There are 2 NF7-s boards....one says this:
ABIT NF7-S ,nForce2 SPP chipset Support AMD Socket A with 200/266/333 FSB ,8X AGP,SATA 150 ATX motherboard Retail
Specifications:
Supported CPU:AMD-K7 Duron/Athlon/Athlon XP Socket A
Chipset: NVIDIA nForce2 SPP chipset with MCP-T
FSB:200/266/333MHz
RAM:3x 184Pin DDR Supports 3 DIMM DDR 200/266/333 (Max. 3GB)or
2 DIMM DDR 400 (Max. 2GB)
IDE:2 x Ultra DMA 33/66/100/133 (up to 4 Devices)
Slots:1 x AGP8X/4X, 5 x PCI slots
Ports:1xFDD, 2xSATA,2xUSB2,2xPS2,2xCOM,1xLPT and Audio Ports
Onboard Serial ATA: Supports transfer rates 150MB/s (1.5G bps)
Onboard Audio:6-Channel AC 97 CODEC
Onboard LAN: 10/100Mb Operation supports ACPI & Wake on LAN
Onboard Firewire: IEEE 1394a at 100/200/400MB/s transfer rate More... Model#: NF7-S
The other says this:
ABIT NF7-S ,nForce2 SPP chipset Support AMD Socket A with 200/266/333/400 FSB ,8X AGP,SATA 150 ATX motherboard Retail
Specifications:
400Mhz FSB
Chipset: NVIDIA nForce2 Ultra 400 with MCP-T
FSB:266/333/400MHz
RAM:3x 184Pin DDR Supports 3 DIMM DDR 200/266/333 (Max. 3GB) or
Onboard Firewire: IEEE 1394a at 100/200/400MB/s transfer rate Model#: NF7-S
Please help, which one do I want? I also called to get more info and they said the 2nd one I listed is a "newer version board" but when I look at the pic, it doesnt have mounting holes around the CPU. Im a little confuzled...
Specifications:
FSB:200/266/333MHz
Specifications:
400Mhz FSB
FSB:266/333/400MHz
