Ok...here we go
the objective: good, quiet performance, for a bargain price (<30). I understand that a Sk6 would be better, but i simply cannot afford it...im only 15; an extra 20 bucks is a fairly sizeable amount. Beyond that, to my research, I have yet to see any huge differences between this group of fans, and the more highly rated Sk6's, etc...if heat does become a problem, i can always let up on the throttle...or open the case and put a 2ft fan beside it hehehe
btw, it is for a 1.2ghz (or maybe 1.0) tbird, to be OCed to 1.4ghz+
From my research, I have found these to be my options thus far: GlobalWin FOP 32-1, GlobalWin WBK38 (with a new fan...i h8 deltas), Taisol CGK 742092, or ThermoSonic ThermoEngine
Anyway, with that WBK, if i get it, I will remove the delta, and replace it with a (QUIETER! yay) 80mm case fan...the switch works fine, you can even use Globalwin's clips.
As for the 32-1 and CGK, I've read that their performance levels are fairly close, though i am not sure as to which is best.
And the ThermoEngine seems to have gotten raving reviews from everyone except Overclockers.com...hmmmm...btw, if i get this unit, it will not be with the delta.
note: oddly enough, Radiate says that the WBK38 has more C/W than the FOP 32-1...how can this be?
It seems as if any one of these would work well enough. But, im really not sure...what do y'all think?
thanks,
-eric
thanks,
-eric
