Which overclock would be better for me?
gplracer
i currently have a 1700+ running at 215x11=2365 on a 8RDA+. Would it be better to run this computer at 220x10=2200? I can not get the 10.5 multiplier to work so that one can not be used. Thanks!!!
altec
polka dot ninja
Doylestown, PA
I dont think that sacrificing overall Mhz for higher FSB will benefit you really. I would try to get the FSB up a little more with you 11x multiplier.
bafbrian
Atlanta, GA
I myself would say go for a higher FSB, but keep you multi.
I have got my other computer, a Barton 2500+ at 10*225, I like having a higher FSB, that is just me though.
mrpops2ko
WOW can U give us a comp spec I can only get to 167 X 11
G
gplracer
mrpops2ko here are some specs and some scores for 215x11
8RDA+ C1/A1 stepping
hyperx 3500 ram - one 512mb module
slk800
1700+ "L" 1.5v 307 week cpu
4200 GF4
SiSoftware Sandra cpu score of 8811/3513
SiSoftware Sandra memory score of 3171/2938
3dmark 2001SE 13440
altec
polka dot ninja
Doylestown, PA
I am a little confused, Why would you sacrifice overall Mhz for a few Mhz higher FSB?! If he is already in the 200Mhz range, what is the extra few going to do when the overall CPU Mhz is lowered?
