Which pin mod for me?...Bartons and K7D
Vito
Iowa
Got a pair of XP2500s and want to use them on the K7D.
I did the L5 mod, now which pin mod do you guys suggest I use based on www.ocinside? I'd like them to run about 2100mhz if possible.
I am in the process of finishing my own K7D install and I started at 15x.
At 100Mhz you will get 1500, 133Mhz will give you about 2000Mhz, and using the BIOS I have been able to raise the FSB all the way to the max. (150Mhz) so that gave me 2250Mhz which is not too bad to start with given that I am using air cooling :)
William
