- Aug 21, 2001
- Candia, NH
Alright, i know about Ohm's Law, and stuff like that, but i'm a bit iffy when it comes to what u do with the solved equasion.
Let's say i have a 12v power supply, and i wanna tone it down to 7v. I'd do the following, if i'm correct:
12 12
7= ----- then, 7x=12 then, x= -----
x 7
Which reduces to 1.71. Do i need a 1.71ohm resistor, or a 171ohm resistor? I heard somewhere that you multiply ur result by 100, but now i'm just confused.
Also, i put this in gen hardware since it is sorta a power supply question, but not really, and had no clue where else it should go. Don't hurt me mods!!
12 12
x 7
