Hey all,
I am getting a router for my father's house, which I will be living at since he is closer to my school. My Dad.... is not that technology literate, so needless to say I will be the only one using the wireless in the house.
My room is directly above the office room where the modem/new router will be.
Besides schoolwork, I will be primarily gaming and downloading fairly large files (Skyrim mods and such). This will be done through wireless since we have no way of routing an ethernet cable up to my room. I want a good connection in which I can get good reception all throughout the house. I don't want any drops in connection, and good latency while playing games online.
I have already bought this wireless adapter for my pc:
http://www.newegg.com/Product/Product.aspx?Item=N82E16833704045
That being said, I'm looking at 2 routers at the moment, 1 budget router and the other one is more expensive, both very good reviews:
http://www.newegg.com/Product/Product.aspx?Item=N82E16833166064
http://www.newegg.com/Product/Product.aspx?Item=N82E16833704038
These are both Wireless N I believe because I am told that's the way to go. Obviously the TP link is better than the Rosewill, I could tell from the price difference, but is the TP Link overkill for my needs? Is the TP Link only marginally better? I just don't want to waste an extra $30 for features I don't need.
Side question. Does 150 Mps differ that much from 300? Since I will never achieve either of those speeds I assume not.
Thanks guys!
Thanks guys!
