Read some reviews that many boards dont fit these heatsinks and would like clarification on what ones fir this board. I dont really want to bend any capps, so would like one which fits out of the box so to speak.
Oh 800U is good to go as well out of the box. Stick with one of the U series if possible and use the mounting holes. You don't want to rip your socket off.
the SLK-800, 900, and SP-97 are all awesome heatsinks. But keep this in mind. Bigger fans are not always better...
I had a 92mm tornado on my 900A and the temps were actually 2C higher than they were with the 80mm tornado. I guess the deadzone was just that much greater on the 92mm.
Bearing in mind im in the UK, and only the SP-94 is available with lead time of 4-7 days.
I think il go for the 900U as its in stock, £27 with free shipping!
