Which tubes fit thermaltake pacific rgb fittings
psrb191921
Can't find petg tubes that fit thermaltake pacific rgb fittings, they're 12id/16od mi've tried thermaltake v-tubler and ekwb 12/16 petg tubes and only one thermaltake tube (1 from 8!) fits ok, all other tubes just push the orings out
Your best bet when it comes to hard tubing is to stick with the same company fittings and tubing.
Thats why I'm asking. I've tried thermaltake v-tubler with the same size and it doesnt fit. Only one tube from 2x4 packs fit, probably thermaltake has crappy quality control
