I personally would wait for the T-breds to come out. They'll be here in just a few weeks and they'll be .13 which means they'll overclock better. I believe they'll start at 1900+ If you can't wait and you need one now, I'd either get a 1600+ or an 1800+ Probably go for the 1800+ seeing as how they are so cheap now.
wait for a tbred 1900+, will be under 200$, or get an agoga or agnga(this one preferably)1800+, good chip, i wish id waited 4 one, oh well i love my chip now
-Malakai
its not like your current setup is taht bad. Also you have a SDR board. if you get an XP i would upgrade to a DDR board to just to fully take advantage of the XP.
i too would upgrade the board but that means buying ram aint
they arent too cheap nowaday
i'd try to find a AGOIA xp 1600. in another trhead in here NEO ran his at 160FSB outof the box, at default voltage!!! could be a fluke, but that is what i would get.
Already have a DDR MB with a 1.4 TB, so I bought an 1800+ from newegg.com today for $120, free shipping. I'll upgrade the 1.4 TB to an 1800+ and upgrade my 1Ghz TB to the 1.4. Eventually I'll buy enough cheap parts to build another system to reuse the 1Ghz TB.
