whick water cooler?
peewee
someone lemme know which watercooler is the best for cooling my tbird1333 down, for around 120-140 bucks...
thanks
mitch
A quality water block, pump and tubing will eat up that money. You will still have to get either a radiator, or fab a cooling tower and a reservoir. Take it from someone, who always bought as cheap as possible, only to have to re-purchase again to get what they truly needed to start with. Spend the money wisely, the first time.
Hoot
I think i am going to go with the aquastealth 2 kit with the aquaflow upgrade radiator for 152 bucks anyone recomend this kit for beginners?
peewee (Apr 25, 2001 04:05 p.m.):
Yes, and ask Brian from BE Cooling to send you one of his new prototype waterblocks....he just sent me one, and it outperforms my old Danger Den block by 3 degrees. Also, you want the AquaCoil radiator.....its the only cube radiator designed specifically for water cooling......it has better fin and tube placement. Plus it mounts better than Danger Den's 'Cube'.
Klark (Apr 25, 2001 07:53 p.m.):
yeah i got the aquacoil with it, i called brian and he said the new waterblock is not ready to ship yet., ill order one when it comes out if it is that much better...
That kit is a great beginner kit, I got one and am very pleased with it. It was a great introduction to watercooling. Of course I'm gonna upgrade the radiator because my 1.33 and my pelt are making too much heat for that radiator to handle.
