Alrighty then!
SageTV has been deployed for about 5 days...very stable.
The "fast forward" and "rewind" functions are different than a normal DVR. They are "skip forward" and "skip back"...you can program whatever times you want here. I have "skip forward" at 30 seconds, and "skip back" at 10 seconds. You can cruise through the commercials really fast. It took a bit to get used to this, but I actually like it better.
My wife approves of the setup now...and finds it easy to use as well.
The only remaining issue I have:
- If you press "guide" on the remote from the main SageTV screen, it brings up the search menu
- This is because I have programmed the Harmony 650 and FLIRC to emulate keyboard commands
- The "guide" has no meaning from the main, "non-TV" menu
- Fortunately, I was able to program the "escape" key into the remote
- If you accidently do this, you just have to hit "escape" on the remote
Not a show stopper, but a bit annoying.
I ordered the 2nd NVIDIA shield, Harmony 650 remote, and FLIRC yesterday...will be here soon.
I'll get this setup and deploy the 2nd NVIDIA shield box.
Assuming all goes well, I'll be returning my cable boxes in about a week or so (and start saving over $50 per month!
