that can answer the questions of the dumbest guy?
Ok, now that you're here I have some questions that I have not been able to find answers for....which means they are stupid. (I have an EP7KXA)
In my soft bios I can adjust bus speeds from 83Mhz up to 115Mhz. In all cases a PCI bus divider is applied. I can make my 750 CPU run at 859 (3dm2k1 reading) with 115 FSB here. (I am assuming that the PCI and AGP settings were applied automatically, I'll check that later.) So how do I get to 133mhz FSB?
I also have a jumper on the board that offers a CPU clock of 133mhz so 7.5 X 133 =997.5. Is the max I can overclock? ...33% increase seems high. But I think the bus speed and CPU clock are independent of each other, right? So would the max be 9.975 *115 = 1147 mhz? It would certainly be dumber than I am to overclock that far but is this a correct calculation?
The BIOS offers the ability to run the memory at either -33, +0, or +33 Mhz faster than the selected bus speed. What's the disadvantage to that?
One review said this, "A set of jumpers offers the boards voltage tweaking, with 1.6,
1.65, 1.7, 1.75 and 1.8v selectable via a combination of 5 DIP switches...." but then didn't say why or when you would tweak the voltage. So here I am asking why? when?
One last thing, at 750 mhz after running all night the bios said the CPU was at 91 deg F, and the system 93 deg. Last night when I was screwing around, I was running overclocked at 825 and 862, both had temps of cpu=96 and sys=93 (i may not have let the 862 run long enough for an accurate comparison). I have a heatsink and double fan, is that gonna be enough or should I get a chassis fan? I don't know if I have thermal grease there, either as bought the mobo with cpu installed. At what temp should I get worried?
Please help...only you can prevent forest fires!
Also, without any system, vid card, or registry tweaks I have benchmarks of:
2084 @ 750; 2249 @ 825; 2430 @ 862
With Radeon 64 DDR and 192 MB cheapo RAM, any good?
Doing all the tweaks from speedguide.net what can expect? roughly?
Thanks,
Thanks,
