These parts are spec'd with a max 95'C junction (transistor) temp. I know new technology chips must stay below 105'C junction to ensure long-term life (+10yrs) so AMD may even have some pad with the 95'C spec.
If we throw in another 10'C pad down to 85'C max junction and allow 10'C delta between the transistors and the bottom of the CPU package (articles with data say it's only 5'C delta) where the motherboard temp sensor touches, then we should be OK with a 75'C sensor reading, right ???
You might not be able to overclock the 1.1GHz much higher because higher temps hurt performance, but if your system is stable at 75'C, I don't understand what else there is to worry about. Am I missing something ?
If AMD specs it at 95'C junction, then it should reliably operate at that condition for a long time. Again 95'C junction = 75'C sensor ( allowing 10'C of pad ).
I look forward to your feedback, as I am puzzled by all this money being spent on keeping the temps in the 40-50'C range.
Hinge
Hinge
