- Dec 11, 2003
This is my case...
http://www.antec.com/us/pro_details_enclosure.php?ProdID=93700#
1. The front grill I cut out so its whide open just exposing the filter. I have a 120mm fan as the intake blowing at 94cfm.
2. I cut a 120mm hole on the side to put a 120mm fan which blows 107cfm and ducted it so it blows air straight which is also filtered.
3. Rear exhaust fan is stock which is 120mm and blows 56cfm
4. I cut a 120mm hole on the top and put a 120mm fan there which blows 79cfm
I put my dvd burner on the bottom 5.25 slot. My main harddrive is in a 5.25 adaptor which I put above my dvd burner. The slot above that is empty but, the slot about that is where I have my Hardcano 9 fan controler.
I can reach room temp at idle while the fans are blastin but, just can't while at full load even when there are no filters on the intake fans.
If anyone has any sudjestions please share. Thanks
