Ok, well... I ditched my Axp 3200+ (A mistake to buy anyways) for a newegg AXP Mobile 2500+. My stepping is IQYHA 0407 VPMW.
So, I have an Antec TruePower 550w PSU... should be fine. Asus A7N8X Delux Rev 2.0 with 1007 bios... not the best OCer... but whatever.
I'm using a Koolance PC2-601 (dont have time for a home-grown water cooled setup) and the gold CPU-200 block. Also have a GPU block on, not a big deal though. Using AS5 etc. Corsair matched 512 low latency PC3200 sticks... 2-3-2-6 timings, etc.
My problem is, my OC still sucks major. I can't hardly prime95 for 5 minutes at 2.6GHz, even at 1.825v vcore. When I do try and run that high, my temps are through the damn roof for water cooling... MBM is saying 47-48 degrees C on die! I'm running 12 x 205 for 2.465GHz ... 1.75 or 775 v (I don't remember) and 44-45 deg C! I'm FPU priming it right now, but I'm not really happy with this overclock.
I know I live in florida, I know my ambeint temps are probably way high at 77-79 degrees F, and I know my mobo isn't the best, but what can I do? I can't overvolt past 1.825 on my A7N8X, and when my proc runs full speed at those voltages anyways, the MOSFETs on the mobo are searingly hot.
Whats holding me back right now? Florida temps, mobo... whats up? I can't figure this out!
Thanks
-----Nate
Thanks
-----Nate
