why is my network connection doing this?
Lt. Max
Seattle, but im Estonian
i was transferring files from one comp to the other and this is how it transfers them.. it seems like theres a lot of collissions or something.
this is screenie of network activity...
tia
max
David
Forums Super Moderator
Hmmm.. is it a direct connection from one PC to the other? What are the transfer speeds like?
Lt. Max
Lt. Max
i was doin it through a router.. i noticed it at first.. then i changed the router and it still did it.. i dont have a crossover cable right now so i couldnt try direct connection..
o yeah.. and i looked bhind my comp.. my NIC card lights went blank when the network connection dipped.. so it like turned off for a sec
max
Lt. Max
Lt. Max
hmm.. im sending to my brothers computer that worked fine.. might be drivers on my friends computer then. ill tell him to check it.. its integrated lan on msi nforce1 board
max
