Stan
Guest
- Thread Starter
- #21
Here is what I did. I redid the plumbing to go from the pump, to the radiator, to the block, and then back to the pump. I first tested the flow of water through my system by timing it for one minute. The setup had a flow rate of .5 GPM. I then tested the ambient temperature of the cooling solution, It read 25C. I then proceeded to run Prime95 and the CPU temp rose to 46C from 32 C and the cooling solution rose to 29C. Air coming from the radiator never really seems to be that warm. Do you think the block could be the problem or is the temp probe on the MB just off by that much? I don't know what to do next!
Thanks
Thanks
