- May 12, 2015
Sooo the Asus strix 1080ti PCB is different from the reference card.. Not sure exactly whats different about it, probably something to do with the power.. But regardless.. All the waterblocks from various companies are licensed... Alot of people say thermaltake copies and i thought so too until i realized how many companies have the same designs.. There is no way it can be a copy it has to be licensed from whoever originally built it there are too many similarities between companies to not have a license agreement..
Anyway all that asside, my 1080ti has a thermaltake block on it, i got it because its well the only block i could find for a 1080ti asus strix except 2 other companies and this one the only one that had RGB on it, and the RGB syncs with the 10 thermaltake fans and controllers i have. The only thing i HATED about this block was the thing has a metal plate in the front. The acrylic or whatever plastic they are using today goes over some of the power junk and so it had to be hollow with O rings and a metal plate was put over top.. This allows liquid to flow overtop whatever asus put in there and to the VRMS or Mosfets.. The problem is the 3 brands i found all had this metal plate.. Why couldnt they have used a acrylic plate ??? Maybe because it would have to be too thin and that would risk cracking or something.. i have no idea..
So i purchased it unable to find one that was clear.. I just had a few drinks and fired up the pc and somehow i came across a Bitspower 1080ti asus strix block... It has that plastic plate in the front so you can see the WHOLE block in the front... Thats exactly what i wanted originally.. So frustrating.. Below are the two blocks.. See the metal plate.. its so unsightly... ugly... and i have my gpu vertical.. Im considering... heavily on buying that Bitspower block.. am i insaine to waste $180 for something like this metal plate ? That and well the bitspower has RGB but only 50% of the block while the thermaltake is 80% of the block. And i can control each led to any color i want, the bitspower im not sure if i can do that.. Its probably a 1 color control for the whole strip.. Im just curious what you guys think... Money isnt much of an issue, granted id hate to blow 200$ for something stupid.. I could attempt to re-sell my thermaltake block though... What do you guys think... that plate is just so unsightly or am i just being a drunk idiot lol.
Also should note the thermaltake block itself is one peice.. and the VRM section is big enough to cooldown the VRMs and also for some reason cools down the resistors next to it, the intructions tell you to put the thermal pads on the small rectangle resisters soldered to the board.. The original asus heatsink was this way too, this bitspower block.. is actually two blocks.. the 2nd small strip is for the vrms but it only cools the vrms it doesnt touch the resistors.. I dont see why resistors need to be cooled down but yea its worth noting the differences
https://www.amazon.com/Bitspower-Wa...sr=8-1-spons&keywords=asus+strix+1080ti&psc=1
https://www.amazon.com/Thermaltake-...-fkmr0&keywords=thermaltake+1080ti+asus+block
