Why so low?
DaMobster
Illinois, U.S.
I'm running the system in my signature, and the scores I'm getting with the virus scan disabled is just below 18k in 2001 SE, and 6623 in 03. is there anyother way i should better my system to get higher scores (other than re-formatting my computer) or am I just stuck with the depressing scores I have now?
cubaxp
Be sure of disabling de Anisotropic Filter and the Anti Aliasing settings before do the test...
Gautam
Senior Benchmark Addict
SF Bay Area
CircuitBreaker8 said:
8,000 in 3dmark03? Thats not happening with that graphic card
True.
I don't know much about nVidias, but for '01, you want to be using the 44.03 drivers; they give you something around 1k-2k more.
Papsomax
Kansas City area
Actually, you may need to check you card oc settings...sometimes when the oc settings are tooo high, it will degrade your cards score...try default settings and work up from there....
paps
