- May 23, 2002
So, with wide screen LCD's and the prevelence of other LCD's coming into the gaming realm I felt there needed to be a nice thread made.
In this thread I am also going to try to convince you want to buy a widescreen LCD, and to avoid all 17" and 19" "normal" LCD's (this is addressed later)
First off, for links I would like to include:
http://www.widescreengamingforum.com/forum/
This forum is dedicated to finding ways to get games working in widescreen mode, and answer specific questions which I won't adress.
A list of games which do and don't support widescreen gaming:
http://www.widescreengamingforum.com/masterlist.php
Now, if your favorite game you play can't be played in widescreen do not fear.
The 2 widescreens I've used, (the dell 2005FPW, and 2405FPW) will let you set the screen to display 1:1 for pixels, aspect stretch, and stretch.
with the 1:1 setting the display will center the image at the native resoltion of the monitor and black out the surrounding...so it looks good and isn't jacked up...for example, if you run it at 1600x1200 on a 2405FPW you will have 2 black bars on the left and right which take up 160 pixels wide each (because the native res is 1920x1200).
the aspect stretch will keep everything in it's aspect ratio and stretch the image to it's limit...for example, running 1280x960 will cause the image to stretch to it's max but retain the 4:3 resolution...and again leave black bars on the left and right.
stretch will take any resoltion image and stretch it so it fills the whole screen...this will distort the way the image is supposed to look.
I leave mine at 1:1...if your video card cannot drive a high powered game and you need to run say 1024x768 and want to utilize most of your big screen then you should run aspect stretch...I personaly would never run full stretch.
Ok...so that's nice you can play your games like normal and stuff...and a lot of games support widescreen...but what does this widescreen do for me?
Well it honestly depends on the game. HL2 is my favorite example for why you should goto widescreen gaming.
Here is a link comparing 16:9, 16:10, 4:3 and 5:4 resolutions (56k warning):
http://www.ocforums.com/showthread.php?t=375461
As you can see you actualy have an advantage over other players with the widescreen! And...(this is why I say stay away from 17 and 19" LCD's) you see a heck of a lot less running the 5:4...or 1280x1024 resolution that LCD's have!
On my monitor I actualy run 16:9 with the 1:1 setting so I get 2 very slim black bars on the top and bottom...but I see more in HL2 (I run 1920x1080 instead of 1920x1200)
I can't give testimonials for other games so I'm gonna open the floor for other widescreen gamers out there....screenies comparing 16:10 would be nice
oh and if you use your computer for DVD watching..well widescreen is what DVD's are meant for.
*EDIT* SSS posted this, some good stuff!
For widescreen wallpaper, this is the place to get them.
They have hundreds, all for free in all screen sizes and all widescreen sizes.
http://interfacelift.com/wallpaper/index.php?w=1680&h=1050&sort=date&id=&page=1
