- Sep 25, 2001
- Bedworth nr Coventry UK
ok here's the story i recently got myself an ashtek water cooling set up the antaric one with north bridge and vga included i set this up on my 2500xp barton using an abit nf7-s rev 2 mobo.
this is where it gets wierd before this i had a monster copper heatsink and fan and could run all day long at 2.2 3200xp and now with the waterblock installed i run cooler but cant even overclock the cpu past default current temps are 34 idle .
could it be that i have damaged the cpu when tightening the block down but i was told if i had done this the cpu would be slow and run really hot and at 34 degrees i dont see that as hot unless its the water cooling system doing a great job at keeping it low
hope you can shed some light on this
thanks in advance
ps
if i have damamged the cpu any suggestions on what chip to go for and how to tell the wife i need a new cpu
thanks in advance
ps
