- Dec 18, 2000
- Kent, UK
For some reason, my lovely 2-3 week old PEP66 has started working less efficently than my old GlobalWin FKP32.
It all started, this afternoon. I get bored in the afternoons, (as I'm unemployed currently) and my ISPs Authentication server was up the creek (PPP_TIMEOUT ERROR). I decided to fold all of my cables so there was less interference with airflow through the case. Everything went according to plan (Both IDEs and floppy folded in three, then half again), my SCSI lead folded only in three, with my CD-Soundcard lead going through the middle of it (bon idee, non?).
Whilst I had the sides of my case off, I decided to see if i could get an RPM readout from my fan, by plugging the yellow wire onto the mobo header. I got a dead fan, pulled the plastic plug bit off the end, slapped the RPM wire in position, and plugged it (with the help of Blue Tac and a pencil) onto my CPU fan header (the header was killed by my Delta, FYI). It worked. Great.
I wonder what speed the Delta spins at? After unplugging the case from the mains, flicking the power switch to drain any residual power, I pulled my slocket, laid it on my desk, and went about swapping the std YS-tech for the Delta (swapping RPM monitor cables as I did).
Plugged slocket back in, plugged Power for fan onto 3-4pin adaptor, plugged RPM monitor onto board.
Then I was called for dinner.
After dinner, I returned to my PC, fired it up, and there was nothing, except the fans and harddisks/CD drives spinning up.
I reset the BIOS, unplugged all hard/floppy disk leads, and it fired up. Great. I went about plugging in lead, firing up, until all the leads were in. Then it stalled just before entering windows (Single cursor flashing at the top left of a black screen). Unplug from the main. Try again. No go!
Get old pII 400 down. I know this works! After resetting the bios, etc., etc. again, it had loaded Windows 98 (First Ed) fully and I tried my ISP again. Bugger- The problem of Free (no call charges) Internet access, is there's no chance of getting on at peak times.
Swap Delta back for YS-tech. Boots and screen goes dead when BIOS access is attempted. Reset BIOS. Try again. Nothing. Removed all leads again. put leads in one by one.
It went on like this for hours, until I thought about the Alpha. I took it off, replaced it with the FKP 32 that it replaced. Fired it up. Windows came up in a trice.
Regooped the Alpha with Artic Silver every way possible. Wipe with Acetone to remove any residue from last time. Then on chip with Credit card. Try again. F***s up. Wipe. Chip with surgical gloved finger. F***s up. Wipe. HeatSink with Creditcard. No dice. Wipe. Heatsink with gloved finger. Nothing. (by nothing I mean runs fine @ below 100MHz FSB. As soon as try to go to 100Mhz with BIOS or SOFTFSB, it will either fail before loading the GUI of windows, or in the case of SoftFSB, will freeze, so only way of retification is to pull mains plug from PSU.
Currently [email protected] 850 with the FKP32, and the Delta (delta's usage because YS was still on the PEP.
Any idea what I should do. The bottom of the PEP is fairly mangled by the top of my CPU slug (as shown in attached pic).
What should I do?
Please help me. I spend £30 on a heatsink thats now stopped being as efficient as my old trusty FKP32.
What should I do?
- Lap it?
- Attempt to Return it?
- Try to sell it?
- Other (Please specify)
