CandymanCan
Disabled
- Aug 14, 2003
- Woodbridge, Va
Iv had this black ice extreme for a long time now going on 3 years, and i have it set up with 2 fan shrouds along with 2 92mm fans, my pump and rad and T line are external not in the case.
Will this rad be able to handle my Cpu overclocked, and my 6800Gt/Ultra overclocked.
I kinda wanan keep the temps below 50c for both, and my cpu reaches the upper 40's doing load already and idle's in the lower 30's. How much of a temp increase do you think i would get. Should iget rid of my 92mm fans and go for 2 120mm ones and just use the mount's on the raditor ? Im also kinda broke here and i might be ordering this waterblock with the 6800 Attachment so the price is ganan be $51 pluss the $12 for the PSU sleeving Kit im buying. After that im broke so will my 92mm fans do ?
Also will this be restricting to my Pump its the 1048 Eheim and its pumping through the rad cpu already.
If anyone knows a website where i can buy some psu sleeves and that waterblock for a little cheaper then $51 for the block that would be great
