- Jul 15, 2009
Hello. This is my first post
Anyways I just bought a new setup and fairly nervous to overclock. I am trying to overclock a 2.3ghz AMD x4 Phenom quad core. The cooling I will be using is the MassCool 5F9001B1H3 CPU Fan. It's specs are:
Fan Type: CPU Cooler
Socket Type: 939
754
940
AM2
AM2+
Fan Speed: 3200 RPM
Noise Level: 32 dBA
Air Flow: 36.43 CFM
Heatsink Material: Aluminum
Bearing Type: Ball
Voltage: 12 V
Connector(s): 3-Pin
Fan Dimensions: 80 x 80 x 25 mm
Life Hours: 50,000 hours
Socket Type: 939
754
940
AM2
AM2+
Fan Speed: 3200 RPM
Noise Level: 32 dBA
Air Flow: 36.43 CFM
Bearing Type: Ball
Voltage: 12 V
Connector(s): 3-Pin
