will i need a cpu shim for a waterblock
johan851
Insatiably Malcontent, Senior Member
Seattle, WA
If you're going AMD, I don't see why not. It makes me feel safer, and they're only a couple bucks. I think they're worth it.
iNSiGMA
Ohio, USA
IS there a danger in using an Aluminum CPU shim with a copper waterblock? I had purchased one when I was getting stuff for my wc setup, and when I recieved it I asked here on the board if there would be a problem using a Al shim w/ a Cu block and nobody ever answered me :-/
johan851
Seattle, WA
Don't see why there would be. My shim is aluminum...nothing's going to corrode or anything like that.
=ACID RAIN=
Kingwood, TX
Unless you tossed your shim in your resevior, no, there is no chance of a reaction.
I don't use a shim myself, just never had a need for one.
eXCeSS
New York
i got a shim on my 2800+ just for a piece of mind.
DOHCrazy -- yea all athlon shims work for bartons.
mumrah
mumrah
DOHCrazy said:
Theres not shims for bartons is there?
The shim i got is CompUSA brand, and it's copper and fits my Barton perfectly
DOHCrazy
The Colony, TX
hmm, all the shims ive seen say 'NOT for Barton' but ill make a trip to compusa and get one, ive always wanted one, just thought i couldnt use it.
mumrah
mumrah
Well i did make my temps crazy unstable, but that was only because it lifted the heatsink too high off the die
Mikeonatrike
BC Canada
Yeh make sure the shim is seated properly. Me and my buddy were watering his shuttle and his shim wasnt seated on his barton.....we started it up and nothing but some beeps. IT wasnt touching at all!!! Chip survived though...
