Will K7S5A take PC2700 333mhz memory
maxima88
I was just wondering if they're compatible.
If so, will it make a big difference if I replaced my pc2100 266mhz crucial w/ a pc2700 333mhz memory stick in reference to increasing my fsb from 146 to 150 (my system locks up at 150)?
I'll will be a 256meg swap.
Its a question alot have asked, that I wish someone that works in a sellers shop should test. But since they are so against overclocking they wont test it to make a extra sell in selling higher quality ram. Maybe they will test the k7s6a atleast since its spec sheet has it in writing that it can be used with it.
It seems the normal rules would apply. I'm using PC 2400 instead of PC2100. Why not 2700. I think backward compatability applies as far as it working in your system.
As far as allowing a higher overclock many things could hinder that.
1. Is the ram the reason you can't get to 150?
2. What is the cas latency of the PC2700?
3. Power Supply.
4. PCI divider....etc.
Thanks. I figured since memory is backward compatible that it would work.
I may be mistaken ... but I thought not all memory is backward compatible. For instance, some PC133 SDRAM will not (I believe) run at 100 MHz or 66 MHz.
I would be VERY interested in some research data.
If the DIMM has SPD, it should be fine.
The Serial Presence Detect (SPD) chip is an EEPROM that contains speed and design information about the module. The motherboard queries the chip for information about the module and makes adjustments to system operation based on what it finds.
I think the weak link in turning up the FSB may be the chipset?
Mine locks at 150 also. I think keeping the chipset cooler may help. I could be wrong, just a thought. Could be the ram also. Anyone else know?
I would agree with this,
From the research and testing I have found that the chipset is, well, shall we say slightly unstable. Some people say a cooler has helped, but I can't see where any data or any documented testing has been done. Besides I don't see the temps being all that high on the chip.
Would be interested in seeing if this truley is where the wall comes from (I hit it also).
I haven't tried switching to 150 fromt he BIOS yet, just through CPUFSB which could be why it locks. However my system already gets kinda unstable after about 2 or 3 hours running SETI at 147. It's either the RAM or the chipset, just wish I knew which one.
it's been my practice to use a nice blue orb or something similar on the chipset. (northbridge)
and a plain heatsink with thermal adhesive on the southbridge.
in some cases it helps, others i don't notice...
but, cooler, is always good :)
i'll be building with one of these boards soon, but i was'nt intending to overclock it. seems like a great board for a normal box.
when i want to O/C, i go for a board made for it.
IMO, 148 FSB is pretty good and i'm not sure why you'd complain? LOL
I finally hit 150fsb at stock 11X multiplier.
I did it by increasing to 150 thru bios.
Ran Prime95, Sandra and PCMark 2002 benchmarks for over an hour last night.
I have a 10k resistor in series w/ a 10k pot so I can vary my vcore from 1.89 to 2.02
