will my 700 duron go to 1.1Ghz??
cookedcomp
Mt. Brudges, Ontario, CA
here's my system at present
a7v133 rev.1.04 (1004 bios)
voltage mod (max 2.5 volt)
duron 700 (152*7, 1064Mhz)max 43C watercooled vcore is at 2.288
133 mhz 128 infinion ram
fugitsu 10Gb hd
GeForce 256 (170 core, 332 mem)
56k v92 UsRobotics modem
300w psu
i've been having a tough time with this system, can anyone tell me how to get to 1.1Ghz if it is even possible on this sytem? anything would be apreciated :)
mine wouldn't boot at 1100 the highest i got mine to run stable at is 1026. your voltage goes higher than mine, so you should be able to get more(if you have good cooling-heatsink/fan) try uping your voltage to 2.10v and try 11x100/33, you should get there
well for some reason it didn't unlock. if i were you i would take a look and see if you made a mistake, it took me a few times over with the pencil to get mine to unlock
umm, whiskey i think he unlocked it fine...its just he didnt change it because hed rather up the FSB, which he did to 154mhz.
and cooked, i dunno...1.1 is near the max of a duron 700. i would play with the multi settings...you might have maxed out yer fsb, try 7.5#147 and see what happens.
i would be very careful about upping the vcore more....anything past 2.1 is the danger zone and your near 2.3. but, its your choice.....
biztyke (Mar 19, 2001 02:19 a.m.):
well it took a fresh install of windows but i got it!! 1.103 GHz!!! the temps stayed the same pretty much and i'm still useing 2.288 vcore
