dont get a 200w computer power supply.
you need a power supply designed to run at the voltage of the pelt, not a computer psu that is designed to run multiple voltages.
computer psu's wattage gets split up between the 5v, 3.3v, and 12v lines... you WILL NOT be able to use the full wattage on any one rail, but must look at the PSU to determine how much you can use for the particular voltage.
what is the voltage and amperage of your pelt?
you should determine the PSU you need by figuring out how much amps are needed and on what particular voltage.
a 156w pelt isn't going to draw 156w, it's probably going to drawing over 200w off the 12v line (according to darrenct's statement that it runs at 18 amps, and hooking it up to a 12v line). also note, some pelts run at different voltages, so you might even have to get a 15v psu or something like that.
hope this helps.
