Will my PSU cut it for my upgrade?
fluxcapacitor
Some of you know I'm upgrading to an A7V133 and 1.33/266 Bird. That said, given everything else in my system, which you can see by clicking the link in my sig, should my antec pp303x 300wtt PSU be able to cut it? I found the enermax 350wtt for $60, but is that even enough?
the antec will be fine ....also ,watercooling usally can be done with a lesser PSU,unless your using a DC pump ,because there are only 1 or 2 fans
I run my 1.2ghz 266 on a KT7A with a powerman 235w psu ;)) works a treat look at the stuff in my case below
