- Aug 29, 2005
Admittedly, I don't know diddly about OCing. Ok, now we've gotten that out of the way... I really want to learn this stuff. I've read the stickies, I've Googled for hours, I've been made fun of and laughed at. There are just some things that are not clearly explained. For example, I read the sticky from Drissler (sp?) about OCing memory, but in the section on how to OC the memory, it really doesn't tell you HOW to OC the memory.
As my sig says, I have the PC4000 CB memory. But, it doesn't run at DDR500, it runs at DDR400 with the memory clock on auto. If I run it at 200MHz, it indicates DDR400, which is what you would expect to see, however, if I change the memory clock to 250MHz, it actually drops it to DDR260 according to Memtest- the weird thing is that the bootup screen indicates DDR500. I am only running one stick right now because my other one is bad. I'm running the system completely barebones- CPU, Vid card, one stick of memory.
Now, my understanding is that with an AMD system the memory has to run at the same speed as the FSB- syncronous. So, I went into the BIOS and set the memory to 250MHz and the FSB to 250 MHZ, and that doesn't work. I have the BIOS set to boot into Memtest and it would get to the point where it would normally enter Memtest, but then it just reboots, so I obviously did something wrong.
Can someone tell me what LDT is? As in LDT/FSB frequency ratio?
Also, I have read about the multipliers and OCing, but I'm not sure where the multipliers are in the BIOS.
I actually have a lot more questions about multipliers and the whole synchronous operation issue. I think I'm not understanding that correctly because it's pretty obvious that people are not running their FSB and memory at the same frequency.
