will these fit a scythe infinity?
A cheap alternative would be to fasion paper clips into one :)
but if you must....
If it looks like the Infinity clips, chances are it will fit.
I would not suggest it. If you own a Scythe Ninja you will know that the hub of the fan will hit the aluminum fins if you have it in a pull configuration. You need to provide some spacers to clear the fins. Why don't you just duct the rear of the Ninja with your case exhaust fan instead?
Maybe this might help you:
http://svc.com/120duct-hr01.html
Good luck,
Bryan d
