Can't tell you if you don't tell us what case it is.
looks like an alienware case.
That said, theres no real way to know. If they are using dell's proprietary motherboards, then nothing will fit lol
Which would be weird because it looks like it's ATX.
I/O at the top left, expansion slots at the bottom left, but there's only 6 expansion slots so it may not fit a full length ATX board.
I have a lenovo intel board and case that "looks" mini atx, except its 7"x7" instead 6"x6". NOTHING will fit except that motherboard. Wouldn't shock me if they did some crap like that for alienwares.
Where do I find out?
This is probably my final build (albeit I might go for a slightly cheaper CPU)... Do I need to get a sound card too or does the motherboard cover that part?
What's the highest I can overclock that CPU to?Look at this instead:
http://pcpartpicker.com/p/jhkR8d
The 4690K is plenty for gaming, especially OC'd.
Edit: Damn, double post. Sorry.
ATMINSIDE, the last build you recommended for me has some slight compatibility issues.
The G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory operating voltage of 1.65V exceeds the Intel Haswell Refresh CPU recommended maximum of 1.5V+5% (1.575V). This memory module may run at a reduced clock rate to meet the 1.5V voltage recommendation, or may require running at a voltage greater than the Intel recommended maximum.
Ignore that... People run 1.65v+ all day long.
