Will this work?
largen101
After input from people I have changed my selection to the following from that listed below, this is ready to purchase I just want to check and make sure everything is compatible.
Case: ASPIRE X-CRUISE -BK Black Steel ATX Mid Tower Computer Case $65
CPU: AMD Athlon 64 3200+ 1GHz FSB Socket 939 Processor $173
Motherboard: ASUS A8N5X ATX AMD Motherboard $92
Memory:CORSAIR ValueSelect 1GB (2 x 512MB) 184-Pin DDR SDRAM Unbuffered DDR 400 (PC 3200) Dual Channel Kit System Memory $75
PSU: Fortron Source FSP400-60THN-R Blue Storm $57
HD:Western Digital Caviar SE 250GB 3.5" SATA 3.0Gb/s Hard Drive - OEM $99.75
GPU: ASUS Geforce 6200TC EN6200TC256/TD/64M Video Card - Retail $51.50
Sound: CHAINTECH AV-710 8 (7.1) Channels 24-bit 192KHz PCI Interface Sound Card $25
DVD ROM: ASUS Black IDE DVD-ROM Drive Model DVD-E616A BLACK - Retail $25.99
DVD-RW: ASUS Black IDE DVD Burner 2X DVD-RAM Read Model DRW-1608P2 BK - Retail $48.99
LINKSKEY LKA-CR15B 19-in-1 USB 2.0 Black Card Reader/Writer - Retail $13.99
GRAND TOTAL: $737.22
That is it, will probally get some fans later once I see how the box is. Anyone see any problems, will this all hook up with what is provided? Thanks
Yeah, everything looks fine. Just make sure that Fortron has the 20+4 pin connector and SATA and PCI-E power connectors (it should, but i'm not 100% sure).
if you plan to game then i would suggest getting another gpu. the 6200 will only hold you back. i would suggest either the x700pro or 6600gt for ~$50 more.
Add a floppy.
No games, can always upgrade later if I start, right
castroman said:
Umm i would say atleast the 6800GS it is the pwns for the cost
I mean i am upgrading from a 6200 to a 7800GT with my new build and I have to say i didn't even know there was a 64mb verson of the 6200 i mean mine is 256 AGP
Make sure your mobo would support that type of video card, ie. AGP with AGP or PCI-E with PCI-E.
Might I recommend a different DVD burner? The BenQ DW1640 or NEC 3550 are both great choices.
